- Jan 18, 2000
- 840
- 1
- 81
This is the sorround sound system I just went out and bought
http://www.1800customersupport.com/products.aspx?view=462&p=79&sc=26
This is the motherboard I have
http://www.newegg.com/Product/Produc...82E16813131595
Anyway I had a problem hooking my computer up to my old system. Old system only had RCA inputs. (Whack) So I was using stereo to RCA cable and those movies sounded fine. The ones with the Dolby Digital Plus. Now I got this new system which has optical in. So I got a optical cable and now connected it to my reciever. It works with music and stuff and most movies. Just the ones with Dolby Digital Plus don't work. Did I buy the wrong type of system, or is there a setting I have to change? I hope I don't have to take this back :/
Also I'm using Windows 7 64 bit. Thanks!
