Ok I've spent about 3 weeks building this computer, err getting the parts for it, they all finnaly get here, and I put everything together, and I turn on the computer to see nothing happens, the screen stays blank. No as far as you have already guessed im no pc genious. Anyways here is the setup
1.1 GHZ with FOP-38
KT7-Raid
2 75GPX Drivers
1 Dvd Drive
SB Live Value
GeForce 2 GTS 64MB
2 Nics
and 1 stick of 256 mb crucial case 2 133 MHZ memory
Now first insticnt was that I had my ide/raid cable's in the wrong way, so I just pulled them all out. I mean the bios should show up on the moniter at least even with no drives actually installed? Well still no go either way.
So next I try moving the memory to different slots, no luck, I still need to try a dif stick.
The only other thing I can think it might be, is that I fried my CPU, EKKK.... please not this. I did everything I was told to do, I took off the thermal tape, added a layer of artic silver(used a bit too much, but still shouldnt be the problem. And then attached the two together. I took the heatsink off, and everything looks alright.
ANy help is much apreciated, thanks a ton
GHURD
1.1 GHZ with FOP-38
KT7-Raid
2 75GPX Drivers
1 Dvd Drive
SB Live Value
GeForce 2 GTS 64MB
2 Nics
GHURD
