Does your car have some type of "power" mode?
PingSpike
21,758
603
You mean like the big red overdrive button on baloo's plane in tailspin? Yeah, that was totally awesome. To bad he burning it out so early on in the series.
Iron Woode
31,311
12,824
no.
more like the red button on top of the gear shift in Mad Max's supercharged police interceptor.
waggy
68,143
10
Originally posted by: jtvang125
Mine has a power, normal, and snow mode. It's a blast to drive in power mode but after a quick dash I can literally see my gas gauge move a few notches lower.
hey whats the make model of the car?
radioouman
8,632
I had a Saturn that had a normal and performance mode...
but if I want my Dakota to shift later, I just get out, adjust the detent cable, and get back in and drive ;)
PingSpike
21,758
603
no.
Was that feature even in mad max? In the road warrior I always thought that button turned some extra cylinders on and off in the engine to conserve gasoline.
Iron Woode
31,311
12,824
no.
http://www.youtube.com/watch?v=yST7yn6rk1E&search=road%20warrior
4 mins in you will see it.
91TTZ
14,374
Originally posted by: Zenmervolt
He's talking out of his ass. The button on the transmisson only affects the transmission's shift points and downshift threshold, it doesn't make any alterations to the engine's mixture.
And yes, my car does have a power mode. It's called setting the boost at 15 PSI and flooring it.
ZV
Actually, there is a chance that it does in fact change the fuel mixture and timing on some cars.
I know that on my 300ZX, there is a different fuel map for 5th gear as opposed to the other gears. When I shift into 5th, it uses a different fuel map that runs leaner, optimized for fuel economy. There's no reason why a car manufacturer couldn't use different fuel/timing maps when certain buttons are pushed.
You never really know until you look at the maps in the ECU.
Ronstang
12,493
18
I have different cars for different purposes.....a little "power" switch just isn't going to cut it.
jagec
24,442
Although not a true manual it does have a "manual" mode giving you electronic control over the shift points. Power mode is for a totally different purpose. It increases the air-fuel ratio with quicker and higher shift points. You can totally feel a difference in performance in power mode at the expense of gas mileage.
Shens on that one, google "3-way catalytic converter". If they don't run near stoichiometric, the cat won't work, and the EPA will ream them.
My bike has a "performance economy" mode..it gives you phenomenally high mileage along with excellent performance, but vastly increases your chances of dying in an accident. There appears to be no way of turning it off, either :)
TraumaRN
6,893
63
24V DOHC V6
And umm gas pedal on the right...i love flooring it and watching the tach hit 7000 instantly and feel my car jump :) then i get sad when i feel it ready to shift again around 75-80 but i have to slow down cuz i cant afford another ticket :(
K1052
52,917
46,872
flicking the shifter to sport mode adjusts the shift points for better performance, kills my mpg though
