Does WPA slow down wireless traffic?
pookguy88
1,426
I don't want to lose any speed by using WPA, will it slow down my wireless connection like WEP did?
JackMDS
29,549
425
How about trying it?:shocked:
It takes 10sec. to uncheck the WPA if you do not like it.
:sun:
Merlyn3D
2,148
:sun:
How about an answer if you got one? For me, I don't think I can set up WPA unless I want to reconfigure all my client machines. It's easier to just ask for other people's experiences.
InlineFive
9,599
It really depends on how fast your hardware is. For my 700Mhz PIII laptops going from WEP to WPA-AES took 1/3 of my connection speed away from wireless clients. But as they just surf the web this isn't a big deal.
That's why JackMDS said, "Try it!"
pookguy88
1,426
:sun:
How about I can't because my wireless card doesn't support it? :shocked:
Dude, YOU ASSumed incorrectly...
:sun:
:sun:
InlineFive
9,599
:sun:
:sun:
:sun:
"I don't want to lose any speed by using WPA, will it slow down my wireless connection like WEP did?"
Thanks for giving the community plentiful information about your setup and what you planned to do with it. We throughly understood that your unspecified networking hardware did not support WPA. We also assume to the best of our knowledge for scanty posts like yours.
pookguy88
1,426
Originally posted by: JFG
Yes, there will be overhead. You will lose speed. I'm not sure how much in relation to WEP though
why couldn't i get a simple answer like this from the beginning?
pookguy88
1,426
Does it really matter what my setup is??
Will WPA not lose speed on certain setups??
Enlighten me
InlineFive
9,599
I did give you an answer based off of my network's performance. The effect on each network is different depending on how the hardware handles the information.
Enlighten me
JackMDS suggested that you try it on your setup because performance does vary between network setups. We had no idea that your hardware did not support it. And your mocking response to his post didn't help at all.
And as I have stated many times above, WPA will make networks lose speed. It just depends on your setup as to how much speed will actually be lost. And what you use it for. The 33% speed loss was worth it for occasional .doc, .xls and web browsing. If you need as much bandwidth as you can get for something like huge .avi files you should probably go wired.
pookguy88
1,426
i wasn't asking how much it varies, the question was simple, does it, or does it not slow down traffic??
its a yes or no question
And how was I mocking??
skyking
22,737
5,883
all of the security measures have an overhead price.
For surfing, it will be unnoticed.
For file transfers on the lan, it will be noticed.
I would say 25% overhead is not a bad guesstimate average, but like others have said, it varies. I do not use wireless to make large transfers over the LAN, myself. The performance hit is therefore unnoticed.
