imported_SLIM
Two lines of thought here; I'm betting you guys can easily answer both even though I've not had any luck finding a direct answer with web searches.
#1 Does the type of security protocol implemented have any effect on staying connected with a wireless connection (increased hardware overhead, something)? The main cause for this question is that I'm having a tough time getting consistent wireless connection b/t my vista laptop with intel 3945abg and D-link 624. I'm guessing that the security protocol (I'm using WPA2 AES and would be ok with going back to WPA if that would help) has very little to do with connection stability, and I'll keep trying different channels etc.
#2 As far as security is concerned, I'm using MAC filtering such that only designated MAC addresses can connect to my router both wired and wireless and I'm using WPA2. Is there anything else I can do to improve on this (aside from adaware, avg, windows firewall)?
Thanks.
Thanks.
