Does Vista Basic use less hard drive space than Home Premium?
In terms of installed files, an educated guess would be yes because it wont have media center edition, IIS etc installed. If the question is whether or not it is a significant amount, then it would be no. Page file, indexing, shadow copy, prefetch etc should be the same on both.
The difference is quite slight. It's not worth worrying about. Buy a big hard drive if 1 or 2 GB is that much of a concern.
