Does Visio suck or am I retarded?
  • Visio sucks
  • schneiderguy is retarded
Status
Not open for further replies.
Markbnj
Elite Member <br>Moderator Emeritus
Moderator
Sep 16, 2005
15,682
14
www.markbetz.net
Honestly, I prefer Google drawings for most of the simple flowcharts, architectural diagrams, etc., that I used to do in Visio.
glenn1
25,383
1,013
BPMN ain't rocket science and Visio is Microsoft so you get what you pay for. Plenty of alternatives if you care to use them. Gliffy is currently being talked up in our organization. Open Office Draw if you want to go that route.
MarkXIX
2,642
Visio is amazing. I use it to do scale drawings for home projects, flowcharts, even map relational databases. You're doing it wrong...
88keys
1,854
12
Vizio is okay, but so are Honda Civics....
The point here is that you get what you pay for.
poofyhairguy
14,612
318
This year's Vizio LED's feature FALD panels, which is a technology that some companies don't even use on their high-end models.
If you TV shop based on the sticker price you are begging to get screwed.
Sho'Nuff
6,211
121
What is there to "figure out"? Basic functionality is broken.
For example, connecting two points that are on the same horizontal plane. No shapes in between the two points. Should be a straight line between the two, right?
Nope. Visio makes the line go backwards away from the point you're trying to connect, and then it loops back around :hmm:
Turn off autoconnect points.
Either that or hit shift or ctrl while drawing the connecting line.
cytg111
23,937
13,438
Incoming necro.
Yes its ef*'in retarded. Awsome on some points and yet so effen retarded on others.
Jeffg010
3,435
Ordering a license for Visio is reason enough for it to suck. All I know is here at work the license you need depends on the amount of boxes you need. So 500 boxes will cost one price and 600, 700, 1000 all cost a different price. Also if you create in the pro version you can't open it in the standard version. MS can go fuck off.
Ns1
55,418
1,598
you mean like every other standard piece of corporate software?
Status
