Does this system has enough power for X800 XT PE?
gevorg
5,070
Hi all,
I finally decided to upgrade my Radeon 9700Pro to X800 XT PE (AGP). My current system has a 380watt PS (it came with Antec Sonata). Will this PS handle the new graphic card?
Here are the specs of my system:
Athlon64 3000+ on Asus K8N-E Deluxe
Corsair 512MBx2 PC32000 CAS2.5
Pioneer 109 DVDRW
WD Raptor 36GB, Seagate 200GB & 160GB (7200rpm)
EMU 1212m sound card
ATI AIW 9700pro
Thanks!
Update: clarified model version
mwmorph
8,877
it should but which one are you getting? the XT or theXL? the XL uses less power.(around 70-77W)
Nov 11, 2004
10,855
Originally posted by: SuperTyphoon
yes it will, they hardly use different amounts, an xt is an overlcocked xl.
Actually, the XL is an underclocked XT. ;)
Yes, it should work fine. The x800 series consumes a little less energy than past generation 9800s.
Soccerman06
5,830
actually the x800xl is a different core than the x800xt/pe so it cant be an underclocked version of the x800xt ;)
Soccerman06
5,830
well since Im lazy, you can look it up yourself Anand, but off the top of my mind its core R423 and it runs at a 110nm instead of a x800xt's 130nm.
But I could be wrong about that.
