Originally posted by: Mday
the salesperson lied to your mom.
sadly that seems to be the case.
What I recommend that you do is try out the software that all these players use FIRST and then decide whether or not to return it.
Try itunes
Try Windows media player
Try napster
try rhapsody
try simply using internet explorer.
Once you decide on one, then choose the best player of the bunch.
for the msot part, with itunes, the ipod nano and the video are the best (and really only choices but very good ones) and with WMP or napster or rhapsody, the iriver players seem to be the best. the x5 iaudios [sic] are very good too.
Keep in mind that if you choose to go the route of usign windows explorer, there are otptions for ALL DAPs that make that possible
