Does the VisionTek Geforce 2 GTS come with a heatsink/fan?
erikiksaz
5,486
Does it come with a fan? If so, is the fan any good, or should i replace it? I don't plan on ocing it, but i want it to stay relatively cool.
Viper GTS
38,107
433
Yes. The GF2 GTS reference design stipulates a heatsink & fan. The quality of these usually uses something to be desired, but is perfectly fine for normal use.
Viper GTS
Maximus96
5,388
i got a visontek geforce gts also...the stock heatsink/fan looks kinda crappy...thinking about putting a blue orb on it instead...and the stock hsf has no clips on it...so you'll have to pry it apart if you want to replace it
erikiksaz
5,486
Great, i just love to pry off that darn heatsink. At least i could add some new thermal compound.
