K Kung Lau Golden Member Oct 13, 1999 1,001 6 81 Sep 18, 2001 #1 If so, are one set for 60mm fans and other set for 80mm fans? That would be sweet!
M MCS Platinum Member Feb 3, 2000 2,519 0 76 Sep 18, 2001 #2 Yep, two sets. The second set is for the "taller" 60mm fans. You can fit an 80mm fan with the smaller clips anyway.
