Does the Radeon 32 LE have a fan header?
Joony
7,654
i got a radeon fan...stick it on the LE :) i think i will get one soon at newegg...
Joony
7,654
bah...the silkscreen is still there...maybe i can solder some pins on or something...
Joony
7,654
ok, i just stuck this fan into a 12volt PSU and it is loud as heck...but powerful...sounds like the delta 60mm...is the fan meant for like 5 volts or something?
merlocka
2,832
The header is there, you just have to do a litte soldering as they didn't include the connector.
jamesbond007
5,280
Doesn't your motherboard have any extra fan headers? Just buy a 3pin>4pin adapter for your case fan if you don't have a fan header available, assuming you have a case fan plugged into your motherboard.
Joony
7,654
radeon fan takes 5 volts i think..mobo header supplies 12...sounds like a delta fan at 12volts...but powerful stuff
