Does the ink on Laser printer cartridges dry out if not used?
Arcadio
5,637
24
I was thinking of selling some Laser printer cartridges on eBay. They're about 3 or 4 years old. What are the chances that they are dry?
EDIT: I just found out that the cartridges use "dry ink".... still, will they work after a few years of being stored away?
MustISO
12
If I'm not mistaken toner does degrade over time but if they've been sealed and stored properly they might be fine.
Zepper
18,998
Toner is a plastic/carbon composite, so yes it can degrade. Plus most laser cartridges have an integrated drum which can also degrade in corrosive environments. It is generally recommended to give laser cart's a good shake just before putting into service. Nothing to lose by giving it a try. Best idea on printer consumables, is to only buy what you can use within the dating. A deal isn't a deal if you end up throwing it away.
,bh,
Lacour
They should be ok, just make sure that they are thoroughly shaken before use. Toner does degrade a bit. Maybe sell them at a good discount just in case there are any problems.
Cheers
Lexy
printer cartridges
