Does this case come stock with a 120mm blue led fan in the rear and a normal 120mm fan in the intake? Or is the fan in the rear just clear? I really like the looks of this case...but want to add a blue glow if the!
Mine came with a clear LED rear fan as well for the windowed version of the P160. Incidently it also came with front fan. Worth the extra $10 it cost over the non windowed version when I bought it.
Blue, I think one of the led's are dead. I just looked and only two are on, lol. Not that I care because it's the fan being not dead that's the most important thing.
My windowed P160 came with 2 clear 120mm fans. The rear fan had a blue led. The front fan had no led. I have since made some changes to my case but that is what I remember upon first use. Enjoy the case. I like mine very much.
