Aikouka
- Nov 27, 2001
- 30,383
- 912
- 126
Well, I have to disagree here. I just spent all day putting my parts in my 550D (so much more pleasant to work with than my Cosmos 1000), and my CPU idle/load temps have dropped by 5-10°C. After running P95 for twenty minutes my CPU averages about 75°C and peaks at 78°. That's with a Core i7 930 at 4.2GHZ, 1.35V. I've got two front 120mm intakes and one 140mm rear exhaust. The side and top vents are both closed.
http://www.anandtech.com/show/6676/antec-gx700-case-review-just-what-you-can-get-for-5999/5
The Anandtech tests don't agree!
Personally, I haven't gone through and tested it, but my system is a little bit louder than I'd like it to be. I did replace some of the fans with quieter variants (e.g. Scythe Kaze 12), but it's close to the wall, has a 660Ti that's pushing air into the case, and doesn't have a fan on the side. Although, it does have one of the AIO watercoolers on the CPU, and I think I replaced that stock fan with an Enermax Magma.
To be fair, I did look up the 900D again, and it actually did better than I recalled. I'm actually tempted to get one, because the nerd in me really wants to try real water cooling!
It's also much quieter than my Cosmos setup was!
The 550D does have quite a bit of silencing foam!
