Originally posted by: Jeff7
Yes, it takes more energy to turn on something than it uses in X amount of time.
X just tends to be fairly small.
A CFL with an instant start ballast uses a short burst of several hundred volts at startup to ionize the gas. At what amperage, I don't know, but I'd wager that the wattage used is higher than the tube's normal consumption. But it does it for a very short time, so "x amount of time" is very short. The concern with CFLs is that the startup stresses the tube, so it's not a good idea to use fluorescent lights where they're only going to be on for a few minutes with each use. The same holds true with regular long tube-type fluorescents. I don't know if I've got these numbers right, but this is the gist of it:
Philips Alto tubes are rated 24000 hours at 3 hours on-time per start, and 30000 hours at 12 hours on-time per start on an instant start ballast.
This increases by about 6000 hours with a programmed start ballast.
A TV or computer monitor will have a degaussing coil go off at startup. This does use a lot of power, but again, it's only for a very short time.
Stuff with compressors: The startup current draw is very high, and can come close to reaching the limit of a standard circuit breaker. But it's brief. So let's say you get 15A draw at 120V for a full 5 seconds. 2.5 watt-hours from startup. Again, "x amount of time" is going to be
very brief.
