Does the 30d and the XTI take the same battery?
alfa147x
29,307
When I sell my xti should i give the buyer both batteries because if i can use the XTI battery on the 30d i would be glad
fuzzybabybunny
Moderator<br>Digital & Video Cameras
Moderator
Jan 2, 2006
10,455
35
Yeah, those should be fine. Sterlingtek is another good place to buy from as well.
corkyg
Elite Member | Peripherals
27,370
239
Yeah - the B-511 series batteries work for theD30; D60; 20D; 30D and 5D. Don't know about the 40D - haven't seen one yet. :)
fuzzybabybunny
Moderator
Jan 2, 2006
10,455
35
Originally posted by: foghorn67
Told you so. ;)
I've been using Sterlingtek for 4-5 years :confused:
ElFenix
102,393
8,552
uses the bp-511 series according to dpreview
corkyg
27,370
239
OK - so I left out the P. No problem. I have owned all of the above cameras and the same batteries fit all. When the 20D came out, the BP-511A was born - longer life - more mah.
The 3rd party batteries are OK - and cheaper - but most bhave a lesser mah. I know becauee I have a couple of them as well.
The charger that came with the D60 is the best - a dual slot charger. Since the 20D, they are smaller single slot chargers.
Cheers!
Corky
