Sandy bridge or ivy bridge could use zero electricity, be powered by granola and unicorn placenta, and the cost of replacing my Q6600 to buy a SB or IB would take at least 4yrs ($700-800 for the system) to break-even.
Ivy Bridge uses alot less power at load than Sandy.
Your Q6600 uses alot of power actually. CPU and Platform.
Q6600 at Anand idles at ~135W. 3770K at ~75W.
Load wise the Q6600 uses ~195W. 3770K ~128W.
But the main point is you get a massive performance increase.
So savings in idling/fully loaded per hour is 0.06/0.067kWh.
If we estimate say 2 hours idling per day (browsing the web or working on spreadsheets/docs) and 3 hours intensive use, savings = 0.12+0.201kWh per day. Per month electricity savings ~9.63kWh.
http://205.254.135.7/electricity/
Savings per month in cheap electricity states (~8c/kWh) would work out to ~77c, in expensive states (say 17c/kWh) that would be ~$1.64.
Those who leave their computers on 24/7 will see a significant cost savings though, even at 10 cents/kWh. 0.10 * 0.060 * 24 * 365 = $52.56
Like I said in my posts, the difference as seen in the monthly bill is negligible, the bigger savings is by not having to buy bigger heatsinks and being able to use less+cheaper case fans, cheaper case, cheaper motherboards to be able to run a cool and quiet pc.
Let's not forget more power = more heat which = longer AC runtimes in the summer for many people. So older CPUs are using more power that dump more heat then you have to use even more power to get rid of that heat.
It reverses in the winter, though. My 7970 kept me nice and warm during the tail end of winter and colder days of spring. 🙂 But yeah heat exhaust is mandatory, not optional, so it's best to get as close to zero as possible--that way you have the OPTION to use it as a space heater.
You only stress test efficient CPUs?
My fully loaded and 3.3Ghz OC'ed Q6600's ran me $15/month for electricity.
That's $180/year.
The fact that it doesn't use zero electricity means the breakeven point is even farther out into the future (probably more like 10-15 yrs).
No one replaces their computer with a new one so as to save money, no one that has done the TCO correctly that is 😉
