Originally posted by: Zepper
A USB channel is a shared resource. Each device trying to operate simultaneously on the channel will take a piece of the total bandwidth. Put several kbds, mice etc on the same channel and you won't notice much difference. Add an external HD to the same channel and you will notice...
.bh.
.bh.
A hub is sharing one channel. If you plug them directly into the mobo (root ports) then each will be on its own channel. The ports directly off the mobo should all be root ports on separate channels.
.bh.
