Does Silverlight Ever Work?
Perryg114
768
4
Anyone else had bad luck with MS Silverlight apps? There are several apps used for tax appraisals that are handy to have when you are looking for a house. They tell you the exact dimensions and tax values etc of a property. It seems that all of them use Silverlight but few of them work well. Is it Silverlight or just crappy software? This is using XP, and Win 7 with Firefox and IE.
Perry
Sattern
330
Skylercompany.com
I haven't used silverlight in a long time because I can't find any apps that are halfway decent.
I probably works for other people, but not for me.
corkyg
Elite Member | Peripherals
27,370
240
It somehow got installed on my Win7 system, and was updated for two years. I never used it, so last week I uninstalled it. Nothing has changed, so I guess I did not need it. :)
pyonir
40,856
321
haha. I've never bothered to install it and only once has that been an issue. I wanted to see some Olympics highlights and they used it on the NBC site (I think this was either the 2008 or 2010 Olympics). I said "screw that" and didn't bother. That's the only time a site has wanted it.
John Connor
22,757
619
121
I don't use Silverlight anymore since i got rid of Netflix. I used Firefox back then, now I use Palemoon. Silverlight and Java are gone as plugins that you don't use should be uninstalled unless you need them.
14,087
Silverlight needs to die, so does flash, but Silverlight needs to die more before it starts to gain adoption. We need less stupid plugins, not more. At least with flash it works in Linux too, with silverlight you're screwed. Probably why Microsoft made it in first place, so ensure they can try to force people on their platform if it gains mass adoption.
TheRyuu
5,479
14
Ever since Netflix got html5 support I haven't had to use Silverlight although I can't say I ever had any problems back when that was the only option. That's kind of my only experience with it so does that make me lucky?
Netflix's html5 player apparently now works in Chrome as well (even on linux if you make yourself look like a Windows user) on version 37+ (currently beta).
14,087
Wow great to hear that Netflix went with HTML5. Silverlight was one of the main things that kept me from getting an account as my HTPC is Linux.
Aldon
449
What's wrong with Java? The security exploits? Probably, but that might be due to the fact that less people know what Silverlight is than Snapchat.
oynaz
2,449
From Microsoft's point of view, the problem with Java is that it is not a Microsoft product.
Scarpozzi
26,392
1,780
Yeah...they probably hired some firm to code the page and they chose Silverlight in lieu of Flash or some other graphic bandwidth hog. It all depends on what the entry-level programmers last learned when they were in school.
jkauff
583
13
It's also used for Amazon Prime, mostly because it has more DRM support than Flash. The DRM is so intrusive if you change your motherboard/CPU, it stops working until you jump through several hoops. Definitely deserves to die.
