Does S-Video carry sound?
Portend
I know I should have asked this on my last post, but, does audio come through the s-video cable or do I have to run a seperate cable just for sound? To my recelection sound comes through when you plug in a camcorder.
CyberSax
Banned
Mar 12, 2000
1,253
Actually, if your TV supports component video, I'd recommend that you use that. It's much better than S-Video. As for sound, the best route is usually a digital coaxial cable (in other words, any kind of RCA aka Audio/Video cable).
Portend
is there any problem with running s-video and audio cable side by side through a wall? interference etc?
Workin'
5,309
You'll need to run separate cables for s-video and the sound. No worries about interference. You can run them right next to each other or even twist the 2 cables into a braid if you want to.
Unbornchicken
245
S-video = video only.
i would recommend (if this is possible for you) that you run S-video and a toslink (optical digital sound). that combination would be (IMO) the best.
if you cant do that, do s-video and normal R/L audio RCAs
EvilDonnyboy
Banned
Jul 28, 2000
1,103
CyberSax is dead wrong. About composite being better than S-video, I mean.
S-Video is waaaaaaaaaaaaayyyyyyyyyyyyyy sharper and richer in colour than composite. Why do you think they used it to replace composite when they created the S-video cassete standard?
As for the digital audio coaxial cable, yes use it when you're hooking up to a 5.1 reciever.
fr
6,408
Donny, CyberSax was talking about component connectors, not composite.
There's a difference. Component is better than s-video.
Workin'
5,309
Yeah Donnyboy, read the post. And just for clarification, there is no S-video video cassette standard. There is S-VHS and SuperBeta, and machines using those standards often have s-video outputs.
And, all high-end (and some low- and medium-priced) DVD players have composite, s-video, and component video outputs, and component video is clearly superior to s-video, and s-video is clearly superior to composite.
But as far as CyberSax is concerned, I'm not aware of any video card with component video out.
