does reversing the ceiling fan help with keeping the house warm?
Semidevil
3,017
so in theory, what happens is that hot air/heat will rise toward the ceiling. As this happens, reversing the ceiling fan will push the heat up, which will bounce off the ceiling, move out, down and circulate the heat around the house better.
first of all, does anyone do this? do you find that it helps?
secondly, all of my vents are located on the ceiling. I have no vents on the ground. so in this case, will this still work?
FoBoT
63,084
15
fobot.com
yes, i switch the switch on all my fans in the winter
but i don't turn them on very often in the winter, i forget
iRONic
8,383
3,691
Yes. Yes. Dunno, mine are in the floor.
