A two-disk RAID1 can, in theory, double bulk read rates, and will also (in theory) cut your seek times in half for both reads and writes. However, because the data is not striped, read performance for a *single* read is not usually doubled -- since the disks have to seek between chunks, splitting the reads between the disks doesn't help as much. However, if you ran a multithreaded test where it tried to read two different files simultaneously, it should double the transfer rate, since each disk will read full-speed at once.
