Does Powerstrip O/C radeon 8500?
visceral
72
Because when i move the slider up or down my benchmarks aren't affected one little bit :(
I tried that radeon tweaker thing and upon adjust the clocks in any way it immediately garbles the screen and the system hangs :Q
BFG10K
22,709
3,002
You might have to restart your machine to allow your overclocking results to kick in. Also make sure you have the latest version of PowerStrip.
You might want to look at the Radeon Tweaker which you can get from Rage3D.
jamautosound
6,754
Power Strip 3.11 Version 5.1 works fine on my 8500le. Up to 270 Engine 265.5 Memory, up from 250. Boosted my benchmarks by 600 or 800 if I remember correctly.
ADxS
You can't just move the PowerStrip sliders up and down - you have to click Apply.
Like the resolution slider in Windows Display properties...
