Does PC100 and PC133 memory create conflicts?
agent1
14
Just wondering if PC100 and PC133 are compatible with each other. I have a celeron 400. Thanks.
HellRaven
659
Yes they are. the only thing is that it will run at the slowest of the two sticks. So your pc133 stick will be running pc100.
Mark R
16
I have 3 memory sticks on my Celeron 433 system. One is PC66, one is PC100 and the other is PC133.
As far as I can tell, it runs fine. Of course, my FSB is set to 66 MHz.
Jocke
7
Hmm, that's strange you should say that... I thought the FSB speed determins the speed of the memory? Please tell me if I'm wrong! In that case I lied earlier, and my PC-100 doesn't run at 140mhz...:Q
BigToque
11,700
they will be fine if you run at 100MHz FSB. If you try to run at 133Mhz, your PC-133 stick of ram may not be able to handle that speed and cause big problems.
John
Moderator Emeritus<br>Elite Member
<< If you try to run at 133Mhz, your PC-133 stick of ram may not be able to handle that speed and cause big problems. >>
I am sure you meant to say &quot;If you try to run at 133Mhz, your PC-100 stick of ram may not be able to handle..&quot;
