- Mar 3, 2001
- 8,859
- 4
- 0
I know wireless phones, microwaves, holding your tongue right, and the phase of the moon all have something to do with your wireless connection, but over the past week or so this thing has gotten out of hand. Random disconnects as often as 30 seconds, but sometimes up to 20 minutes all day long on two separate laptops. The disconnect lasts for maybe 5 seconds, but it's enough to be a pain. After 5-10 disconnects I have to disable then re-enable my radio just to connect again. I'm just glad I quit WoW before this started happening... Everything was working fine until recently, nothing in our house has changed.
What I have done so far:
Moved the physical location of the router
Changed antenna positioning
Upgraded to newest official Linksys firmware
Flashed the DD-WRT firmware
Changing the channel from 1, to 6, to 11, happens on all channels
Nothing makes a difference, wireless disconnects after all that.
Checked Netstumbler, we live across the street from an elementary school and it picks up something like 12 APs over there, 4 on channel 1, 4 on channel 6, and 4 on channel 11. However, the SNR is in single digits, whereas mine is always between 50 and 70.
Is it dead? Dying? I bought the thing back in December to replace a D-Link that needed to be rebooted daily, but I know I don't have the receipt any more. I have another WRT54G that none of the wired ports work on after a lightning strike, but wireless works great. Any way to cobble together a working one? They are version 3 and 8, so I'd imagine probably not
Any suggestions? Wired connection on my desktops and even on this laptop does not drop when the wireless does if that's any help.
