- Aug 3, 2005
- 9,916
- 2
- 81
My Friend went to Circuit city, to get a new speaker system.
After they installed, it the whole electrical system shorted out. And the car would not turn off. He took the key out and it was still on. (The Engine)
He went to the dealer and when they took a look at it, they said that it was because of Faulty installation. They also said that they disabled his airbags, and they never re enabled them. So if he would of gotten in an accident they would not of gone off. The Dealer Fixed the wiring so that the car would function correctly.
**They told him to go to Circuit city and get the rest of the wiring they put in uninstalled**. So, now that the car was working so that he can drive it. He did not want to bother with the headache with Circuit city because he thought that everything was working properly and did not want them to screw it up again. Yesterday night his car started smoking, and his trunk caught on fire, his back Leather Chairs are all burnt where circuit city worked. He also inhaled alot of smoke, trying to put the fire out.
Does he have a case?
BTW: its an 2006 VW Jetta GLI
*Edit: I talked to him again the Dealer told him to go tell CC what had happened.
*Edit2: It was a Woofer and an Amp that he installed not a speaker system.
Thanks
Thanks
