Sheepathon
It's been a few months since I've taken my tower outside and dusted off the insides with a can of compressed air, so I went and did it. I then noticed that the heatsink on my motherboard was no longer sitting on it, but rather at a tilt. I don't know if it has been like that for a while or if it just happened. After I finished dusting the case, I reconnected everything, etc, and set it back on the ground next to my desk. However, it now is in this position (with the heatsink looking rather useless, yea?).
The heatsink is normally held in place by four clips (locations indicated by the red circles), but apparently the two on the top have somehow fallen off. I am currently posting from the computer that is host to the motherboard shown in the above pictures.
My question is: how worried should I be about this? Do you guys think I should keep the case door open in fear of heat, or leave the computer off at all times possible, etc? Would it be safe to put the case door back on? (it's a bit loud with all the fans inside, so I'd prefer it be closed). Should I go shop for a replacement motherboard? Basically, I'm seeking advice regarding how to best deal with the situation, I suppose.
I'm running a P4 2.4ghz cpu (with its own fat heatsink above the one pictured above) with an Asus P4PE mainboard that I built in Dec 02.
Thanks for your input, fellows.
edit: one more picture
