Does my 16X Lite-On DVD-ROM drive play DVD-Audio discs?
A2KLAU
1,406
Alternatively the next best thing you could do it to obtain a disc and see if it will work.. thats the best way of knowing.. if possible borrow a DVD Audio disc first to save your forking out money to buy one to test.. and find it it won't work.. but to be honist you have a very high chance of one working.. Can't see why they shouldn't..
Albert. :D
Goi
6,772
7
Currently, it won't unless you have a Creative Audigy or Audigy2, as well as either the Creative player or WinDVD with the DVD-A patch. No other soundcard supports DVD-A currently even though a lot of them have the required hardware capability.
uart
174
Goi, I know nothing at all about DVD-Audio disks, but couldn't you still get it to work with any old sound card as long as you played it through the analog out (Analog rather than DAE).
Goi
6,772
7
Well, you will have to play it via analog even if you have a Creative Audigy, since S/PDIF doesn't have the neccessary bandwidth. As for how the signal goes from the drive to the soundcard, I'm not too sure about that but I believe it should be via DAE via the PCI bus. The analog cable in this case is only for stereo sound and the S/PDIF cable again doesn't have the neccessary bandwidth. Also, digital extraction is prohibited due to copyright issues.
uart
174
That's what I meant, shouldn't the analog cable still supply an audio stereo signal that you could listen to with any old sound card. Sure it would be a kind of crippled solution, but if you really wanted to listen to it you should be able to.
Pariah
7,357
20
There's nothing unique about DVD-A discs. Any current DVD-ROM drive can read them, though without the proper soundcard and software player you won't get the high-fidelity audio track. All the audio travels over the PCI bus. It cannot go through the analog out on the DVD-ROM drive because the drive has no idea it's an audio disc and doesn't know how to decrypt the encryption on the disc. If you don't have the Audigy 2 with the proper software, you may still get audio, depending on the disc, but it will be a lower quality Dolby Digital track not the high fidelity DVD-A track. The only reason there is no digital out on soundcards for DVD-A is to prevent copying. You can get it on some HT equipment, either through propietary means or the new I-Link connection which is a firewire implementation that will be the standard for future digital audio transfers.
Goi
6,772
7
Pariah is correct. Without an Audigy, you'll be stuck with the lower quality Dolby Digital track rather than the LPCM 24/96 or 24/192 DVD-A track. The analog cables can't be used due to reasons mentioned above.
eriqesque
704
Originally posted by: thatsright
I bought this 16X Lite-On Internal DVD-Rom drive back in June from New Egg for my new Rig. Now I just bought a Audigy 2 card and it can play DVD-Audio discs, but I'm wondering if the Lite-On drive can support the DVD-Audio format. Of course that this being a OEM drive, it doesn't really say.
Anyone have an idea. Thanks
To answer the orignal question about that DVD player if you have the audigy2 and use they're software DVD-A player YES you will be able to do it.
