futurefields
If you lower graphics settings will the gpu run a little cooler?
Or will it render more frames and thus produce the same amount of work/heat?
And is there a way to say "hard cap" frame rate?
For example, I have a 60hz monitor. I dont ever need more than 60 frames per second right?
Can it be hard capped (without resorting to vsync) so that the GPU doesnt work too hard in games that dont need it. For example I dont need my GPU rendering a 150 frames per second when I play Arkham City. Just enough to maintain 60 fps.
