Does Les Schwab fix CV joints?
Status
Not open for further replies.
Apr 20, 2008
10,067
990
So, do they? I know they do axle work and struts.
Also, this is the first time i'm buying tires. They are for my Impreza. How much do a decent set of tires go for? I don't want to get robbed at the shop when i take it in.
Vette73
21,503
9
What do you mean fix CV joints? Replace them or reboot them?
For tires I always buy online.
Bignate603
13,897
Originally posted by: Scholzpdx
Either or, or which should i do?
It depends how bad your current one is. If you just have a nick in the boot just replace the boot. If the boot is torn up and its been clicking for a while and you've been driving around on it you should replace the shaft.
Apr 20, 2008
10,067
990
Yeah, i've been driving on it since i bought it (approx 750 miles). It is unknown how long the problem has been there.
Will they be able to take care of it?
Bignate603
13,897
Their website doesn't seem to make me think they would. Give them a call if you really want to know though.
Anyways, they're a tire place you'll be better off going to a real mechanic.
Status
