Screen burn Is possible with LCD technology?
Yes, it's possible and in fact quite common. Look at just about any ATM machine and you will see what I mean. However it is not really screen burn like CRT?s get. In terms of LCDs it is generally referred to as "image sticking" which looks just like screen burn on a CRT monitor.
The cause is a bit complicated, but it generally comes from not maintaining the proper voltage (i.e., having a net zero DC voltage, long term) across the LC cells. Any amount of leakage current will turn a cell on slightly causing an image to appear.
It is my recommendation to use a screen saver and change the background pattern. On the bright side, unlike CRT monitors in time the effect may fade. If your LCD has this phenomenon, try running a pure white screen for a period of time, this also can reduce the effect but may not remove it completely.
Manufactures typically will not warranty against image sticking (screen burn)
Lets put one thing to rest, to my knowledge color CRT monitors today are using the same (p22) medium short persistence phosphor that was used many years ago. Thus monitors today are just as susceptible to phosphor burn as they ever where.
