Yes there is a problem!!!!!!!!!!! It seems to affect the hyperx 3500 and the newest nforce2 stepping. The problem exists if you are planning on running dual channel mode over 20fsb synch.
Here is a copy of a letter from kingston:
Thank you for contacting Kingston Technical Support. This Abit NF7-S board
uses Nvidia nForce2 SPP chipset, and from our testings done in lab, Hyper X may
not be compatible with nVidia nForce2 SPP chipset , when 2 pieces are installed.
One piece should work, 2 pieces will mostly likley fail. You may consider using
our regular parts that are compatible with this board: KVR266X64C25/256
(DDR266), KVR333X64C25/256(DDR333), and KVR400X64C25/256(DDR400).
Please let me know if I can be of further assist.
Regards,
Jane Cheng
Kingston Technology Far East Co.
+886-3-5666860 direct
+886-3-5789502 fax
jane_cheng@kingston.com.tw or
technical_support@kingston.com.tw
quote:
We are working closely with Kingston regarding this issue. So far, the problem seems to be a incompatible issue between the Hyper X and the newer stepping of the North Bridge. I can run ANY other PC3500 modules up to 217Mhz FSB =434Mhz DDR @ 2-3-3-6 without any problems on the NF7-S v2.0.
Kingston is working on this issue with NVIDIA right now and we are waiting for a fix from them.
AFAIK, Hyper X has the same issue with other motherboard manufactures as well.
