does it matter if I use a cheap(er) RCA cable...
Aharami
21,205
165
...to connect my car's headunit to the amps? Both have gold plated RCA connectors. Will I be seeing any loss in SQ by using cheaper RCA cables such as those that can be purchased at Radio Shack?
tweakmm
18,436
4
Quite potentially.
You don't need silver magnesium alloy cores shielded by native american pubic hair, but having quality interconnects preserves SQ. Although the old addage of garbage in garbage out comes to mind, so if the rest of your system is junk then good RCA cables arn't going to do jack.
PurdueRy
13,837
4
You can buy my component cable from me, pull off the extra wire and use it as a RCA audio cable!!!!!
Scarpozzi
26,392
1,780
Monster Cables are BY FAR better quality. I don't care what anyone says....look man, if you buy the best, you'll only have to buy one.
<hehehehe....I wonder if he's gonna fall for it>
DingDingDao
3,044
Originally posted by: tweakmm
Quite potentially.
:shocked: :laugh:
Aharami
21,205
165
Quite potentially.
haha...shielded by native american pubic hair
as for the components...
Pioneer DEH-P8600MP headunit
Omnifi DMP1 Digital Media Player
Alpine V12 MRD-M1005 amp (for the sub)
Alpine V12 MRV-F545 amp (for the speakers)
Diamond Audio D661a component speakers
JL Audio 10w7 sub in a sealed enclosure
Aharami
21,205
165
you only have 1 left. I'd need 4 (1 for front speakers, 1 for rear speakers, one for sub, one to connect DMP1 to headunit)
Aug 26, 2004
14,685
Quite potentially.
in that case, spend 20 bucks and get some decent cables...
PurdueRy
13,837
4
damn :(
Aharami
21,205
165
monster is like BMW - yea they're good cables...but they're way overpriced.
not looking to spend $100 on cables...
Aharami
21,205
165
Quite potentially.
would Radio Shack have any decent cables?
What should I look out for to know that cables are decent?
zoiks
11,787
Yea, how come all the retailers took the cheap stuff off and now only stock Monster cable? I couldn't find a decent cable at Target for a good price. Either they had really junk stuff or they had the uber expensive Monster crap.
PurdueRy up there has the right idea. Cablesforless gives you pretty good cables for very reasonable prices.
Aharami
21,205
165
anyone know where cablesforless is located? I need them by this weekend and wondering what shipping method to use..
PurdueRy
13,837
4
11230 N State Rd. 67
Mooresville, IN. 46158
frankgomez75
2,215
I've noticed this too.... quite annoying that you can't walk into a Target or Walmart and find some regular cable.
I despise Monster Cable... will never fall for their marketing again. :|
PurdueRy
13,837
4
Need a 12' component video cable by any chance with that home theater???? ;)
Aharami
21,205
165
hmmm, i dunno if 12' will suffice. will have to go home and take some measurements
pennylane
6,077
Radio Shack's gold series isn't bad and not too expensive. Probably good enough to get the job done. I'd probably get it from a site like the one mentioned above or bluejeanscable.
