Does increased sound quality lower framerates
aka1nas
4,335
Sound processing will typically use up more CPU cycles, especially with an onboard setup. Whether this will be at all noticeable depends on how CPU-intensive the game is.
BFG10K
22,709
3,002
Yes, hence the need for Creative sound cards which typically have much lower CPU consumption than other vendors.
Fistandantilis
845
So even though I have a soundcard, my processor is still dedicating cycles to sound? I thought that the soundcard would take care of that.
BFG10K
22,709
3,002
Yes, your processor still has to generate the raw audio streams. The sound card applies the mixing and effects and if it can do it in hardware that's were you'll get the gain.
Gstanfor
Banned
Oct 19, 1999
3,307
I think that offloading audio to a spare cpu will become a very obvious thing to do in future and I'm quite suprised that current audio drivers don't do it if they detect a dual-core or better cpu.
Fistandantilis
845
Ahh I see, thanks.
Captante
30,340
10,859
Originally posted by: happy medium
Yes it does and even more with onboard sound
I'm 100% sure he's correct because I tested it out with FEAR among others on my Asus Crosshair first with the onboard sound & then with my current X-Fi ... however I have to say that the difference was much more pronounced with the onboard solution which at points dropped frame-rates 25-30% compared to the X-Fi which caused much smaller drops that were measurable in benchmark testing but not noticable to the naked eye.
