W wahdangun Golden Member Feb 3, 2011 1,007 148 106 Dec 27, 2013 #1 just like the title said, i want to connect 2 different office building but in between it, there are "high voltage line". so if i setup 2 wireless 5 Ghz wifi, will i still get good signal ? btw I will using Ubiquiti NB-5G25 Nano Bridge M5 25dbi
MagnusTheBrewer IN MEMORIAM Jun 19, 2004 24,122 1,594 126 Dec 27, 2013 #2 Power is transmitted between 50 and 60 Hz roughly so, no, there is no interference. Induction would be a far more likely culprit. Last edited: Dec 27, 2013
W wahdangun Golden Member Feb 3, 2011 1,007 148 106 Dec 27, 2013 #3 MagnusTheBrewer said: Power is transmitted between 50 and 60 Hz roughly so, no, there is no interference. Click to expand... ok, what a quick answer, thank you, problem solved
