Pedroc1999
If i overclock a GPU without increasing the voltage will it eat up more watts or stay the same?
That is real eye opener but by how much would it effect it by if that is the case. How many more watts would 50 mhz add onto a hd7770
If the stock speed is 1GHz, then going to 1.05GHz would yield a 5% increase in wattage so about 4-5 watts.
Leakage increases as a transistor heats up.Sorry... But What?
I would say yes it could handle that load. If it is unable to do so it will just shut down before some damage occurs (most modern PSUs have OCP). How OCP works you can read here.Would a 550 watt psu with 528 usable handle a fx6300 and a hd7770 crossfire (391watts) and both card reasonable overclocked?
Is that wiv crossfire?
