I just purchased a new widescreen LCD panel. My GF3-128 card has both DVI out and analog out. Unfortunately, the LCD panel only came with an analog d-sub cable. The image quality is great, but I was wondering if it would be even better with DVI. I know there is a digital to analog conversion done on the computer, and then another one on the LCD panel side, if I use the analog cable. If I go DVI, then it will be 100% digital. But is there enough of a difference to notice?
If I had a DVI cable, I would just try it out. But I was somewhat shocked to find that a 6 foot DVI to DVI cable costs 40-50 bucks.
Thanks,
BM
Thanks,
BM
