does dust affect how an amp produce sound?
eviljoker
64
i have this aged old dustful amp and it keeps shuttin off left and right. have to keep hittin it for both speakers to work
ThisIsMatt
Banned
Aug 4, 2000
11,820
Only due to heat. Sounds more like a bad solder joint or other component that's moving as it heats up.
eviljoker
64
yea, it does get intensely hot during playback. what would you recommend to clean the dust? air or cloth?
Eli
Super Moderator | Elite Member
8
Compressed air..
As someone said, it's probably a cold solder joint.
