Does "ATI/Sapphire Radeon 9800 Ultimate" come with a fan or not??!! Apparently it is required!..
Dance123
Hi,
Does anybody have the "ATI/Sapphire Radeon 9800 Ultimate Edition". I believe this silent version has a passive heatsink from Zalman (which version?) but I was wondering if it also comes with one of the silent fans (which one?) from Zalman installed. I believe I read somewhere that the 9800 cards need the fan, so I was wondering if the fan comes with the ultimate edition or not?!
Thanks in advance!
Mike.
I've got one in my rig right now -- no fan, no problems. The fan is *recommended*, and the heatsinks got really really hot when it's running under load, but it works fine. I have mine o/ced to 425/365 stable. I did just order the add-on fan for it, so I'll get a chance to try it both ways.
Zalman sells a low-profile fan that specifically mounts on the ZM-80C (which is what I've ordered). The heatpipe does not have a place to mount a regular fan without some work. However, they also sell a bracket that locks onto a PCI slot screw and lets you mount pretty much any fan/fans over the card (or anything else in and around the PCI slots). Check out their website:
Zalman
Originally posted by: Schadenfroh
does it already have mounting brackets on it for the fan? if so, can it handle a 120mm tornado?
120mm Tornado? Now I have to wipe the Mountain Dew off my keyboard...
Cooling these days is crazy... tornado on the thermalrite.. tornado in frotn back of case.. no tornado on the vid? 40000 dB's later... *puts in earplugs*
