Does anyone sell 2 pin to 3 pin adapters for your power led cable?
amddude
I have an antec 900 case, with an asus p5b board. The problem is, from the front of my case, the power led cable is two pin. On the motherboard, it is three pin (1 pin, space, 1 pin). Does anyone sell an adapter that would split the 2pin to 3pin?
like this, but only in-stock
Edit: Looks like antec will send you one for free, gonna try that route.
Sometimes the 3-pin mobo pwr LED header pins can be used as two as well. Can't hurt anything by trying. If you have a meter, you can check them in advance. I'd bet the center pin is also ground. Or you could cut the connector in half or you could get a 3-place shell. Lots of ways to skin that particular cat.
.bh.
If you took the two female sockets out of the dual plg and used shrink wrap to insulate them they could be used as singles.
