Guys, does anyone know why a PCI-E video card's power connector is only 12v (yellow) and G, while the power connector on AGP 8x video cards (that have them), are 12v, G, AND a 5v (red) line?
Reason I ask is I recently got a new PSU that's modular and it has two labeled dedicated PCI-E modular cables. I was hoping I could use one of these for my AIW 9800 Pro, since I've always heard you should use a separate dedicated power cable for a video card (hence the separate dedicated PCI-E modular cables). But I can't, I apparently can't even adapt it to work with a mod'ed connector since the PCI-E connector is missing the red 5v wire. So I'm wondering that since my card for example uses a floppy power connector, if the 5v line may be "empty", as in it not being needed nor actually connected to anything on the card. If that's the case, then I easily mod the PCI-E cable to work with my card.
If not, then I'm going to have to use one of the huge cables with 4 of the large 4-pin Molex connectors on it just to be able to use a floppy power connector! Even if I adapt one of the 4-pin Molex to floppy connector, I'd still have to use the entire cable assembly for only one device, which defeats the purpose of me getting a modular PSU in the first place.
Thanks.
Thanks.
