My dog chewed through the cord of one of my BA4800 rear speakers. Does anyone know if it's possible to replace the cord at a local shop, or if there is a place to get just 1 rear speaker with a cord? Thanks.
call me crazy but isn't it just normal (albeit thin gauge) speaker wire that got chewed up?
if this is true, you could simply strip both sides and reconnect it yourself with some electrical tape and/or solder. OR, if there's not enough slack, just pay 10cents or whatever for a little piece of speaker wire and make a jumper the same way you would splice it.
