Does anyone know of a way to connect my Playstation 2 to my computer monitor?
pg22
2,644
I'm lucky enough to have a 21-inch Sony Trinitron monitor and I bought one of those VGA boxes for my Dreamcast and damn the games look much better.
Unfortunately, no one has released anything like that for the Playstation 2 even though they said it's VGA compatible.
Does anyone know of a solution?
beat mania
2,451
get an upscan converter, and a RGB cable (ones for playstation works also).
Svideo is horrible on a monitor. And don't even think composite.
denon
295
Yup, what he said...they will and do have a vga converter. It should run you like $20
pg22
2,644
OK....dumb question :\
Where do I get an upscan converter and an RGB cable?
Thanks again!
beat mania
2,451
rgb cables for the ps I occasionally see at electronic boutique ...
you can also find both here [l]http://209.245.246.144/default.asp[/l] - just do a search for xrgb. both the upscan converter and cable will show up. NCSX is a very good company - I buy all my import games (including my JPN PS2 and upscan converter) from them.
