Does anyone know if Lian Li A71B top cover part compatible with A71F??
dsc106
320
10
Looking at this part to replace the top cover to mount the H100 liquid cooler:
Part: T-713B
http://www.performance-pcs.com/cata...=product_info&cPath=130_387&products_id=24603
It says for A71B which seems extremely similar to A71F, does anyone know if the parts will work together? I have the Lian Li A71F. Here are the two cases:
A71F (mine):
http://www.newegg.com/Product/Produc...12343&Tpk=A71F
A71B (case the part is made for):
http://www.newegg.com/Product/Produc...82E16811112144
(discontinued, A71F basically an upgrade)
Dimensions appear to be the same, slight difference in rounding between the spec pages
