- May 19, 2011
- 21,100
- 16,314
- 136
What I mean by 'standard mATX' is a standard size ATX PSU coupled with a Micro ATX board.
I've built one ITX PC that had a standard ATX PSU in, and the other day I had to replace a TFX PSU for a Lenovo PC.
My feelings towards building another as a result are basically, "oh hell, no!", mainly because of the mess and faffing around of trying to route too much cabling into too small a container.
With the Lenovo PC I had to open it back up after installing the PSU because the motherboard power connector was being pressed on too much at an angle (it had the CD drive directly over the power connector, so the connector's cable had to bend at a 90 degree angle).
The only two ways that I can think of to make my life bearable when building small PCs myself would either be:
1 - When picking a case, the case manufacturer says "here's a list of PSUs and motherboards that have fitted well together with regard to length of cabling", and the are sufficient choices on the list to ensure that I can pick what I regard to be good quality parts, or they say "cable x ought to be ycm long for board z so that there's enough cable and sufficient slack" etc.
2 - Modular PSU manufacturers would need to supply cheap spare cabling parts and specify the cable lengths so that a builder can say "ok, I'll try these two lengths of cable for that particular purpose to see which fits best". They might do this already, but considering my experiences with the EU Cooler Master shop for other parts, I doubt it (rip-off central).
The TFX PSU I bought from Seasonic was absolutely bizarre, I can only describe it as "kind of modular"; the PSU doesn't have any cables permanently attached, there are two connectors on the PSU to connect up power cabling, but the cabling that comes with the PSU looks like two cables that have been wired into each other, making it one sprawling mess of a cable which is difficult even to connect to the PSU when you're not trying to force it into a very small case. The cabling has all the standard connectors one might expect.
