randomlinh
yep, my power supply is my problem.. i can adjust the speed, but it's gotten louder over the past months.
++Originally posted by: Carbo
Some good info on quieting your rig here, by Fred Langa.
Originally posted by: DingDingDao
Depending on which mobo you have, the noise could be coming from your northbridge. I have an Abit IC7-G, and the original NB fan was pretty loud. I replaced it with a passive heatsink from Zalman, and it took away a significant amount of noise.
If you're not overclocking, sound dampening material (like dynamat or something cheaper) works really well if you line your case (esp. the seams) with it.
Really? Because I have acoustimat all over the inside of my case, and my FSB can still be changed...
Your FSB can still be changed, but Acoustimat/dynamat, etc are heat insulators. If you start padding your case with it, your temps go up and that can lead to instability especially if your system is overclocked
What he said.
What he said.
My processor has been stable up to 84C before... I think people overexaggerate the importance of temperature.
What he said.
most of them do, from the factory. and you misspelled heat sink.
Originally posted by: fyleow
Actually even with a water cooling rig it will not be silent. I still have my water cooling gear that I'm not using anymore because it's too much of a hassle when you want to take something out of the computer. I've tried running my water cooled computer without fans (except PSU) and it lasted 4 hours before freezing from overheating
Will it be enough if I replace all the case fans with panaflos? There are still 5 of them...I'm not sure if my Zalman cooler's fan can be replaced easily. I've got it on a rheostat right now with it turned all the way down. I'd replace the fans in the PSU but I'm afraid of getting shocked.
