Does anyone else suffer from severe canker sores?
akshatp
8,349
I use a medicine called Rinstead which is available in England. It is a little lozenge type of med, put directly on sore. Usually after 3 or 4 treatments it is gone.
JulesMaximus
74,528
908
I've had them ever since I was a child. I've found that foods rich in tomato (highly acidic) and eating red meat frequently tend to flare them up. I've also found that stress flares them up as well.
Orabase is a good temporary pain reliever...I highly recommend this. It has benzocaine in it which numbs the pain and it coats the area so you can at least eat and live without pain for a little while and you can just squeeze it out of a tube and rub it on the area.
Zilactin is a product I've had mixed results with. If you don't dry the area first it is useless.
There is a mouth rinse by Oral-B called Amosan which is also quite good to take before bedtime. This stuff helps speed healing quite a bit and is great at relieving pain and helping you sleep through the night.
AbAbber2k
6,474
Originally posted by: mordantmonkey
mmm canker sores. Maybe cause i rarely get them, but am i the only person that likes the pain sensation when you bite them. yeah, i know, i'm ****** up.
I don't bite them, but I tongue the sh1t out of them. :eek:
Edit: I also do the salt thing. Hurts like a b1tch, and who knows if it actually helps (probably a myth) but I do it anyway. Placebo effect perhaps?
Jeff7
41,596
19
Huh, well, never heard a technical name for them.
I've had them for years. They come in spells, though they've toned down in recent years. Throughout school, I would rarely go a week without having at least one. At the worst, I had 7 at once, and it was so painful to eat anything. Braces were awful too. It was like having one large sore stretching the entire length of the braces. My mouth never really fully toughened up to them either. That, combined with the constant dull aching of the movement of my teeth just made for a miserable time.
Best one was when I bit my tongue on the tip hard enough that my incisors contacted each other. Went clean through. That was about as pleasant as it sounds.
I have yet to find anything that helps with them. They don't always even require a bite to start them - sometimes they start in places where my teeth simply can't get to.
The only thing that "helps" at all is Orajel, to numb the pain for a few minutes so I can eat or talk. It also doesn't burn like hell like a lot of the other similar products on the market.
moshquerade
61,504
12
56
Originally posted by: Baked
Damn, talk about nasty. No, I don't have any VD in my mouth.
canker sores are not caused by the herpes virus like cold sores are.
but i'm glad the penicillin took care of your mouth VD. ;)
Chunkee
10,391
RAS - Recurrent Apthous Stomatitis...do a google on it, there are some good remedies, via diet etc...however, when i went through a period of severe stress and had them for a few months...the only salvation was a concoction gargle of kaopectate, Liquid benedryl and xylocaine (hurricaine) spray...20% and hardcore 800 mgs of ibuprofen every 6 hours....the xylocaine(hurricaine spray) was the god send... you can get some 20% benzocaine and it should help some but did not seem to help...it has been like 15 years since i have had it...
i know the pain you are going through...it is horrible...zinc tincture i seem to recall helps...
http://www.users.uswest.net/~dallas7/aphthous.html
http://www.whocollab.od.mah.se/expl/ras.html
http://www.guideline.gov/summary/summary.aspx?ss=15&doc_id=4368&nbr=3290
monk3y
12,699
I only tend to get canker sores when I'm stressed. No clue why but it almost always happens.
LanceM
999
Yep, Zilactin for short-term relief. Hurts like heck at first, but it'll help you eat.
Since you're really not supposed to use Zilactin frequently, alternate it with a 1:1 mixture of Benadryl liquid for kids and Maalox. Swish it (don't swallow) around the affected area for a while. Be sure to buy the red Benadryl and the mixed berry Maalox, because it tastes better than most. This doesn't work as well as the Zilactin, but it works.
thomsbrain
18,148
i occasionally get canker sores when i am extemely stressed. peroxyl (a mouth rinse at the drug store) is the way to go for me. it just helps keep everything clean.
and luckily, canker sores != cold sores (teh herp!).
Shawn
32,236
53
L lysine usually helps them heal faster, usually within 3-4 days. It's just an amino acid suppliment. If you are getting them a lot you may be allergic to your toothpaste. I suffer from dry mouth and get canker sores every so often and I switched to Biotene and haven't had a canker sore since. You can get it at walmart (although it's usually hidden pretty well) or CVS.
sao123
12,650
203
I have this dental paste...
Triamcinolone Acetonide Dental Paste SP (0.1%)
it tastes like sh1t and feels like wet sand in your mouth... but it heals most of them overnight.
randalee
683
I get them from time to time. This last week, I was suffering GREATLY from one right near my tonsil, in the back of my throat. VERY PAINFUL.
My doctor wrote a VERY strange prescription to me. He told me I'd need to find an "old school" pharmacy or apocethary to mix it up for me. It was a combination of 5 different chemicals mixed in different amounts, to make up a bottle of "swish". Up to 4 times a day I could swish/gargle the stuff then let it sit in my mouth for 2-3 minutes then spit or swallow it (whichever I preferred.) I'm a spitter.
Stuff looks like green slime when it's all mixed up, and a very thick consistency. You only take 1 teaspoon and swish it. After spitting, no food or drink for 30 minutes. (I asked about that, the pharmacist said it's because of the lidocaine -- makes your swallow reflex not work properly sometimes.) Said if I went to drink water right after, because things are all numbed, I might send that water down the wrong way.
The bottle says: NYS/TCN/HC/LID/PROMETH
If I remember from the instructions/prescription, it was Nystatin, Tetracycline (I think for TCN), Hydrocortisone, Lidocaine, and Promethazine. My doctor called it his "Aptheous Ulceration Cocktail"... Again, I had to find a old school pharmacist to mix it up for me.
The guy was THRILLED that I came to his Apocethary when I showed up. He started pulling out his beakers and vials and went to work! He said he doesn't get a chance to "mix up drugs" very often, so you may find a doctor who can write a scrip for it and a GOOD old-school pharmacist who can make it for you.
It was miraculous for me. I swished a couple times a day for 2-3 days and was cured. Not kidding.
loup garou
35,132
Sh1t, why didn't I think of that?! I still have some lysine from when my cat has ulcers on her lip...duh! Let me go find it.
PricklyPete
14,582
162
I get one at the base of my gum about twice a year...generally when I get overstressed from something going on in my life. Other than the pain and the annoyance when I'm eating or drinking some foods...it doesn't cause me too much trouble. I do hate when they show up though.
Tiamat
14,068
You have to nurish your body by eating good food. Nothing acidic, no chocolate, no milk, no caffeine. If you can, try to get some lidocane. It is extremely hard to swish becuase it is a gel, but you have to swish it without puking (its so thick that it can promote gag reflex) and after about 15 seconds of swishing it and spitting it out, your whole mouth will be numb enough for you to eat food.
At one time, I had an allergic reaction to myself and had more than 30 canker sores in my mouth, along with multiple GI ulcers, and inflamed joints etc. It was a bad time for me.
RaiderJ
7,582
I just swish Listerine a couple times a day, or more as needed. Hurts at first, but then the pain is gone for awhile.
JEDI
29,391
2,736
does it matter which variety? or all of them heal the canker faster?
edit:
hm... Advanced Listerine® Antiseptic?
All other types are just different flavors
MrsBugi
2,481
HOLY CRAP, 30 at once!??!!! :Q I feel faint just thinking about that.
How did you have an allergic reaction to yourself? I'm sorry that you had to go through such a painful experience. :(
MrsBugi
2,481
Fascinating. Where can one find an apocethary and "old school pharmacist" around these days?
fatdragondzc
391
old remedy, it gonna be painful though. Put salt on canker sore and hold salt in while it stings. It'll disinfect the thing and it'll start healing. Really painful though. Keep repeating =P.
JEDI
29,391
2,736
why would the salt heal the canker faster?
wont the salt make the sore bleed, thus making it worse?
