Does anybody make a thing to work with my umbrella holder & my flash trigger
I bought a kit (2 white, 2 silver, stands and umbrella holders) from amazon.
It came with this type of umbrella holder:
My flash triggers are these CTR-301p
They have a 'tripod' screw on the bottom of the trigger which i can mount on my trigger (havent checked the umbrella stand but it should mount on the umbrella stand).
What I need.
1. A good umbrella holder that can work with my flashes
2. Adaptor to fit into the generic umbrella holder with a screw for the CTR-301P's
Any help is mucho appreciated.
iGas
6,240
What I need.
Perhaps you need a stud shoes adapter, and check the box again to see if it is included. And, there are swivel stud shoes adapter that you can purchase as well.
http://www.dinodirect.com/tripod-screw-shoe-adapter-emoblitz.html
w00t! I placed order for 3 of them from dinodirect. Its exactly what I needed and at less than 11 bucks for all 3 from china, it should do the job mighty fine.
