Question Does anybody have recently so much issues with Visual Studio 2019?
YuliApp
486
125
yuliapp.com
Intelisense not working often, lot of display bugs, connection issues to FTP. Since two updates ago. Before it all worked fine
Schmide
5,754
1,046
Yeah. Apparently you need to build your own defenses.
These are mine for one project.
C++:
#pragma warning( disable : 4244 )
#pragma warning( disable : 4305 )
#pragma warning( disable : 4334 )
#pragma warning( disable : 4838 )
#pragma warning( disable : 26451 )
#pragma warning( disable : 6297 )
Stop telling me my shifts may overflow, no one shifts near or past 32bits.
64 bit decided the default operand would be 32 bits, if I add a 32bit value to a 64 bit value just extend it, don't make me explicitly cast it to shut up intelisense ...
I feel better now...
Reactions: YuliApp
Schmide
5,754
1,046
I will admit it did make me do some things better but it's like 100 alarms in a space capsule.
I had this code
C++:
    __m256i reindexTable;
    if (deindexTable) {
        Reindexer(reinterpret_cast<short int *>(&reindexTable), indexTable, deindexTable, 16);
    } else {
        reindexTable = *reinterpret_cast<__m256i *>(indexTable);
and intelisense wouldn't shut up about variable being unset because it can't see past the reinterpret_cast.
It did lead to a better solution, though technically it should produce the same code.
C++:
    union {
        short int reindexTable[16];
        __m256i reindexTableVect;
    if (deindexTable) {
        Reindexer( reindexTable, indexTable, deindexTable, 16);
    } else {
        reindexTableVect = *reinterpret_cast<__m256i *>(indexTable);
YuliApp
486
125
yuliapp.com
C++ is whole another mess of compiler issues. I was so happy what they did with C#/VB but now is getting really bad. Since it started there has been like 4 updates of 1 GB and is still the same :-(
Reactions: Schmide
YuliApp
486
125
yuliapp.com
I had this code
C++:
    if (deindexTable) {
    } else {
C++:
    union {
    if (deindexTable) {
    } else {
i like the "before" code more.
Reactions: Schmide
